Inventor Forum
cut Helical groove
20 REPLIES 20
Message 1 of 21
2822 Views, 20 Replies
cut Helical groove
Can someone help I am trying to cut helical groove as per drawing.  groove design is as per section (A-A) but an angle.  please see attached drawing.
20 REPLIES 20
Message 21 of 21
LT.Rusty
@Anonymous wrote:
see attached.
Interesting solution.
I think you're doing a little more work here than you really need to do, though.  Also, sketch 1 is not fully constrained ...  One other thing to note is that your helical profiles have a slight undercut at the edges, from where the circle starts to dip back in.  This may or may not be actually manufacturable, depending on your available tooling.  It doesn't quite match the drawing though.  (Of course, the part doesn't quite match the drawing either, so it may in fact be correct and I'd never be able to tell!  🙂  )
Rusty
