Inventor Forum
Cut Flange to a Slope
6 REPLIES 6
DewayneH
1482 Views, 6 Replies
What I have is a bracket that sits on a pitched roof (ipt attached). The part was set up to reflect the positioning. On the lower side of the pitch, the easiest thing was to scuplt the flanges to the slope. Although the flat pattern results in some edges not being perpendicular to the face (See image). These show on the drawing. I realize you can remove these in the drawing but it would be nice to not worry about it.
What would be a better way of handling this situation?
Dewayne
Inventor Pro 2023
Vault Pro 2023
6 REPLIES 6
JDMather
in reply to: DewayneH
Extrude the basic shape.
Fillet (bend radius)
Delete the bottom faces and corner radii
Trim the flanges and rips.
Thicken towards the outside.
JDMather
in reply to: JDMather
steps
IgorMir
Here is an alternative suggestion. Please see the attached.
Best Regards,
Igor.
Web: www.meqc.com.au
IgorMir
I like the second version better...Smiley Happy
Igor.
DewayneH
in reply to: IgorMir
I experimented with this method but was wondering if maybe there was something more that could be done after the flange tool to treat the corners.
This is a very good straight forward solution.
Thanks for the help.
Dewayne
Inventor Pro 2023
Vault Pro 2023
IgorMir
Not in the IV 2010, but in later releases the miter corners can be specified while defining the flanges. Or so I was told. But even in the IV 2010 the model still can be improved. In the attached version the whole part is made entirely in sheet metal module. That, in turn, has reduced the amount of entries in the browser.
Best Regards,
Igor.
