Inventor General Discussion
Distinguished Contributor
Anthony
Message 1 of 5 (1,071 Views)
Cut angle section out of circular hollow tube
1071 Views, 4 Replies
12-05-2012 03:53 AM
I have a small section of hollow tube as an IV part which I need to cut to at one end to produce a tapered effect. Attached is a mark up of what I am trying to achieve with the hollow tube. Does anyone have a solution for this ? Thanks
Inventor 2013 Product Design Suite Ultimate
Windows 7 Professional-64Bit 12GB RAM
Intel Xeon W3550 3.07GHz
Anthony Goodwin ~ Cad Manager/Senior Designer
Autodesk Inventor Professional 2013 SP2 64-Bit Edition
Windows 7 HP Z400, Intel Xeon W3550 3.07GHz
12.0GB RAM, ATI FirePro V4800 (FireGL)
No workplanes are needed.
Simply a sketch with 2 connected lines to do the Split.
JDMather
Message 2 of 5 (1,059 Views)
Re: Cut angle section out of circular hollow tube
12-05-2012 05:05 AM in reply to: Anthony
Attach the ipt file here.
Unless I am missing something - it should be a simple Split, Extrude-Cut or Sculpt.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Anthony
Message 3 of 5 (1,035 Views)
12-05-2012 07:05 AM in reply to: JDMather
Sorry for the bad wording on my post, what I forgot to add was that I had attempted this using workplanes but found it a lot easier to simply create 2 sketchs with the desired taper angle on the tube end and split the solid. Thank you for the reply.
JDMather
Message 4 of 5 (1,030 Views)
12-05-2012 07:19 AM in reply to: Anthony
Anthony
Message 5 of 5 (1,025 Views)
12-05-2012 07:25 AM in reply to: JDMather
Many thanks, yes I found the split method to be the most effecive. :smileyhappy:
