Inventor Forum
Cut angle section out of circular hollow tube
4 REPLIES 4
Anthony
2839 Views, 4 Replies
I have a small section of hollow tube as an IV part which I need to cut to at one end to produce a tapered effect. Attached is a mark up of what I am trying to achieve with the hollow tube. Does anyone have a solution for this ? Thanks
Inventor 2013 Product Design Suite Ultimate
Windows 7 Professional-64Bit 12GB RAM
Intel Xeon W3550 3.07GHz
Anthony Goodwin ~ Cad Manager/Senior Designer
Autodesk Inventor Professional 2013 SP2 64-Bit Edition
Windows 7 HP Z400, Intel Xeon W3550 3.07GHz
12.0GB RAM, ATI FirePro V4800 (FireGL)
4 REPLIES 4
JDMather
in reply to: Anthony
Attach the ipt file here.
Unless I am missing something - it should be a simple Split, Extrude-Cut or Sculpt.
The CADWhisperer YouTube Channel
Anthony
in reply to: JDMather
Sorry for the bad wording on my post, what I forgot to add was that I had attempted this using workplanes but found it a lot easier to simply create 2 sketchs with the desired taper angle on the tube end and split the solid. Thank you for the reply.
JDMather
No workplanes are needed.
Simply a sketch with 2 connected lines to do the Split.
Anthony
Many thanks, yes I found the split method to be the most effecive. Smiley Happy
