Inventor General Discussion
2,124 Kudos
Post 11 of 13
Re: cut and paste
01-14-2013 07:30 AM in reply to: Cadmanto
Cadmanto wrote:
I have tried numerous time to select a part in the assembly tree and do a ctrl-C and then a ctrl-V
Didn't read through this entire thread - I assume you have found out that you can Ctrl drag copies of parts from assemby tree to graphics window.
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
1,702 Kudos
Post 12 of 13
Re: cut and paste
01-14-2013 07:54 AM in reply to: Cadmanto
and it has never worked for me.
Hi Cadmanto,
If you select the target part in the browser and press CTRL + C on the keyboard, then click in the graphics area and then press CTRL + V on the keyboard it should work. Keep in mind that the click in the graphics area provides the insertion point as well.
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
Employee
0 Kudos
Post 13 of 13
Re: cut and paste
01-15-2013 12:47 AM in reply to: jsmith923
you are right, I see the same behaviour on my machine.
I have logged an issue (DID1489576 ) for this topic to our internal database so people from Autodesk can take a look.
Thanks for reporting this issue!
Stanislav Sedlak
