1. In the AutoCAD file that you posted, I noticed a couple of
interesting things. First, in opening the file in AutoCAD I was
presented with a proxy message. (See attached)
2. all of the geometry in this file was created on layer 0. Why? was
this an exploded block at one time? Was this originally from a solid
model or mechanical desktop file? BTW, there was no geometry on the
other layers within the original file, which leads me to believe that
somehow this was derived from a solid model type file.
3. As shown in the video, when I went to import only selected geometry
rather than all, the very first line that I picked was only a partial
edge line.
Yes, AutoCAD can produce bad geometry, as well as good. If this is a
representative file then you're going to have problems importing it and
others in order to turn it into a valid and simple sketch.
Dennis Jeffrey, Autodesk Inventor Certified Expert
Autodesk Manufacturing Implementation Certified Expert.
Instructor/Author/Sr. App Engr. Tel. (260) 399-6615
http://teknigroup.com
