"v.valentijn" <Yes..
href="mailto:v.valentijn@ithema.nl">v.valentijn@ithema.nl> wrote in
message
href="news:BFE0E9CFA604AA1FA99887D6B4DBFEC2@in.WebX.maYIadrTaRb">news:BFE0E9CFA604AA1FA99887D6B4D......
I know about the section view.. but this doesn't actually affect
the
assembly? It only gives you the view.. it doesn't actually affect
the
assembly. [correct me if I'm wrong]
So what I'm looking for is - a
similar effect to what you get if you make a
gap or hole through an
assembly.. but, defined by a workplane in which you
simply throw out one
side. I've been contemplating if there might be a
workaround to get this
effect but so far it's not satisfactory at all. Does
anyone have any ideas
on this??
btw. thanx for your responces KJ and mp...
"mpower" <
href="mailto:michael.powers@ridesti.com">michael.powers@ridesti.com>
schreef in bericht
href="news:BE943A3296A650D96C52E631E8D6F70D@in.WebX.maYIadrTaRb">news:BE943A3296A650D96C52E631E8D......
There is a 'Section View' tool in the panel bar for cutting assemblies
and
> looking at 1/4, 1/2, & 3/4 sections where work planes define
the cutting
> planes.
-Mike
An assembly CUT feature?
Rui
message
href="news:BFE0E9CFA604AA1FA99887D6B4DBFEC2@in.WebX.maYIadrTaRb">news:BFE0E9CFA604AA1FA99887D6B......
the
the
anyone have any
ideas on this??
mp...
"mpower" <
schreef in bericht
href="news:BE943A3296A650D96C52E631E8D6F70D@in.WebX.maYIadrTaRb">news:BE943A3296A650D96C52E631E......
and
the cutting
> planes.
-Mike
Yes, I guess that's what you would call
it..
Rui
message
href="news:BFE0E9CFA604AA1FA99887D6B4DBFEC2@in.WebX.maYIadrTaRb">news:BFE0E9CFA604AA1FA99887D......
the
the
a similar effect to what you get if you make a
simply throw out
one side. I've been contemplating if there might be a
workaround to get
this effect but so far it's not satisfactory at all. Does
anyone have
any ideas on this??
mp...
"mpower" <
schreef in bericht
href="news:BE943A3296A650D96C52E631E8D6F70D@in.WebX.maYIadrTaRb">news:BE943A3296A650D96C52E63......
and
define the cutting
> planes.
-Mike
"RuiF" wrote in message
I wasn't asking, I was suggesting.
In your assembly, create an extruded cut
feature.
Rui
"v.valentijn" <
message
href="news:62C92FA1DEDA7F9B8E32BDDD027CA351@in.WebX.maYIadrTaRb">news:62C92FA1DEDA7F9B8E32BDDD027......
it..
Rui
in message
href="news:BFE0E9CFA604AA1FA99887D6B4DBFEC2@in.WebX.maYIadrTaRb">news:BFE0E9CFA604AA1FA9988......
the
the
- a similar effect to what you get if you make a
gap or hole through
an assembly.. but, defined by a workplane in which you
simply throw
out one side. I've been contemplating if there might be a
workaround
to get this effect but so far it's not satisfactory at all.
Does
anyone have any ideas on this??
KJ and mp...
"mpower" <
schreef in bericht
href="news:BE943A3296A650D96C52E631E8D6F70D@in.WebX.maYIadrTaRb">news:BE943A3296A650D96C52E......
and
define the cutting
> planes.
-Mike
"v.valentijn" <
message
href="news:08C2931245E439BBF5D6E1FC5D3D74B2@in.WebX.maYIadrTaRb">news:08C2931245E439BBF5D6E1FC5D3......
Oh.. I missed your point.. well, using the cut
feature was the 'work around' I was trying to use. It just seemed quite a
hassle to first create an extruded cut feature. The trouble about doing it
this way is that I need to know the dimensions of the part that is cut
beforehand.. but that's a bit tricky.
I am assembling parts and need to cut off
anything beyond the workplane, but depending on the exact configuration.. the
size over the part being cut varies. I guess I could try to simply make the
cut feature 'oversized' but I didn't think it was very elegant.. and figured
it should be quite easy to simply use the workplane for CUT instead of having
to define geometry first.
but thanx for your suggestion Rui
suggesting.
feature.
Rui
"v.valentijn" <
message
href="news:62C92FA1DEDA7F9B8E32BDDD027CA351@in.WebX.maYIadrTaRb">news:62C92FA1DEDA7F9B8E32BDDD0......
it..
Rui
wrote in message
href="news:BFE0E9CFA604AA1FA99887D6B4DBFEC2@in.WebX.maYIadrTaRb">news:BFE0E9CFA604AA1FA99......
the
affect the
So what I'm
looking for is - a similar effect to what you get if you make a
gap
or hole through an assembly.. but, defined by a workplane in which
you
simply throw out one side. I've been contemplating if there
might be a
workaround to get this effect but so far it's not
btw.
"mpower" <
schreef in bericht
href="news:BE943A3296A650D96C52E631E8D6F70D@in.WebX.maYIadrTaRb">news:BE943A3296A650D96C5......
and
define the cutting
> planes.
-Mike
"RuiF" <rui.cad@netcabo.pt>
schreef in bericht
href="news:50A707E48620A7F4C0F320BC0D95FF90@in.WebX.maYIadrTaRb">news:50A707E48620A7F4C0F320BC0D9......
If your dimensions vary in one direction, you
can always skecth an enormous rectangle on the plane you want and the use the
ALL option for the depth.
That will leave you safe no matter how your
assembly changes.
Rui
"v.valentijn" <
message
href="news:08C2931245E439BBF5D6E1FC5D3D74B2@in.WebX.maYIadrTaRb">news:08C2931245E439BBF5D6E1FC5......
the size over the part being cut varies. I guess I could try to simply make
the cut feature 'oversized' but I didn't think it was very elegant.. and
figured it should be quite easy to simply use the workplane for CUT instead
of having to define geometry first.
suggesting.
feature.
Rui
"v.valentijn" <
message
href="news:62C92FA1DEDA7F9B8E32BDDD027CA351@in.WebX.maYIadrTaRb">news:62C92FA1DEDA7F9B8E32BDD......
it..
Rui
wrote in message
href="news:BFE0E9CFA604AA1FA99887D6B4DBFEC2@in.WebX.maYIadrTaRb">news:BFE0E9CFA604AA1FA......
the
affect the
So what I'm
a
gap or hole through an assembly.. but, defined by a workplane
in which you
if there might be a
this??
"mpower"
schreef in bericht
href="news:BE943A3296A650D96C52E631E8D6F70D@in.WebX.maYIadrTaRb">news:BE943A3296A650D96......
assemblies and
work planes define the cutting
> planes.
-Mike
