Inventor Forum
cut along workplane
9 REPLIES 9
Message 1 of 10
234 Views, 9 Replies
cut along workplane
Can I set up a workplane in an assembly so that all materials on one side
are cut away?
9 REPLIES 9
Message 2 of 10
You want a section view in the assembly file. There is a button fly out for
section views on the assembly panel bar. Click the button and the click the
workplane(s) you want.
Kathy Johnson
Message 3 of 10
There is a 'Section View' tool in the panel bar for cutting assemblies and
looking at 1/4, 1/2, & 3/4 sections where work planes define the cutting
planes.
-Mike
Message 4 of 10
Yes.. I know about the section view.. but this doesn't actually affect the
assembly? It only gives you the view.. it doesn't actually affect the
assembly. [correct me if I'm wrong]
So what I'm looking for is - a similar effect to what you get if you make a
gap or hole through an assembly.. but, defined by a workplane in which you
simply throw out one side. I've been contemplating if there might be a
workaround to get this effect but so far it's not satisfactory at all. Does
anyone have any ideas on this??
btw. thanx for your responces KJ and mp...
"mpower" schreef in bericht
news:BE943A3296A650D96C52E631E8D6F70D@in.WebX.maYIadrTaRb...
> planes.
> -Mike
Message 5 of 10
An assembly CUT feature?
Rui
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
Yes..
the
the
on this??
"mpower" <
href="mailto:michael.powers@ridesti.com">michael.powers@ridesti.com
schreef in bericht
href="news:BE943A3296A650D96C52E631E8D6F70D@in.WebX.maYIadrTaRb">news:BE943A3296A650D96C52E631E8D...
and
the cutting
> planes.
-Mike
Message 6 of 10
Yes, I guess that's what you would call
it..
Rui
Yes..
the
the
anyone have any
ideas on this??
mp...
"mpower" <
schreef in bericht
href="news:BE943A3296A650D96C52E631E8D6F70D@in.WebX.maYIadrTaRb">news:BE943A3296A650D96C52E631E...
and
the cutting
> planes.
-Mike
Message 7 of 10
I wasn't asking, I was suggesting.
In your assembly, create an extruded cut
feature.
Rui
it..
Rui
Yes..
the
the
simply throw out
workaround to get
anyone have
any ideas on this??
mp...
"mpower" <
schreef in bericht
href="news:BE943A3296A650D96C52E631E8D6F70D@in.WebX.maYIadrTaRb">news:BE943A3296A650D96C52E63...
and
define the cutting
> planes.
-Mike
Message 8 of 10
Oh.. I missed your point.. well, using the cut
feature was the 'work around' I was trying to use. It just seemed quite a hassle
to first create an extruded cut feature. The trouble about doing it this way is
that I need to know the dimensions of the part that is cut beforehand.. but
that's a bit tricky.
I am assembling parts and need to cut off anything
beyond the workplane, but depending on the exact configuration.. the size over
the part being cut varies. I guess I could try to simply make the cut feature
'oversized' but I didn't think it was very elegant.. and figured it should be
quite easy to simply use the workplane for CUT instead of having to define
geometry first.
but thanx for your suggestion Rui
"RuiF" wrote in message
feature.
Rui
it..
Rui
Yes..
the
the
gap or hole through
simply throw
workaround
Does
KJ and mp...
"mpower" <
schreef in bericht
href="news:BE943A3296A650D96C52E631E8D6F70D@in.WebX.maYIadrTaRb">news:BE943A3296A650D96C52E...
and
define the cutting
> planes.
-Mike
Message 9 of 10
If your dimensions vary in one direction, you can
always skecth an enormous rectangle on the plane you want and the use the ALL
option for the depth.
That will leave you safe no matter how your
assembly changes.
Rui
hassle to first create an extruded cut feature. The trouble about doing it
this way is that I need to know the dimensions of the part that is cut
beforehand.. but that's a bit tricky.
anything beyond the workplane, but depending on the exact configuration.. the
size over the part being cut varies. I guess I could try to simply make the
cut feature 'oversized' but I didn't think it was very elegant.. and figured
it should be quite easy to simply use the workplane for CUT instead of having
to define geometry first.
suggesting.
feature.
Rui
it..
Rui
Yes..
the
affect the
So what I'm
gap
you
might be a
btw.
"mpower" <
schreef in bericht
href="news:BE943A3296A650D96C52E631E8D6F70D@in.WebX.maYIadrTaRb">news:BE943A3296A650D96C5...
and
define the cutting
> planes.
-Mike
Message 10 of 10
Yes I think that is what I will go construct now..
thanks for your help Rui 😉
can always skecth an enormous rectangle on the plane you want and the use the
ALL option for the depth.
assembly changes.
Rui
the size over the part being cut varies. I guess I could try to simply make
the cut feature 'oversized' but I didn't think it was very elegant.. and
figured it should be quite easy to simply use the workplane for CUT instead
of having to define geometry first.
suggesting.
feature.
Rui
it..
Rui
Yes..
the
affect the
So what I'm
a
in which you
if there might be a
this??
"mpower"
schreef in bericht
href="news:BE943A3296A650D96C52E631E8D6F70D@in.WebX.maYIadrTaRb">news:BE943A3296A650D96...
assemblies and
> planes.
-Mike
