Inventor General Discussion
Valued Contributor
0 Kudos
Post 1 of 2
Customized Content Center
136 Views, 1 Replies
03-24-2012 10:53 PM
Hi Guys,
I want to make a customized channel with all the dimesnions fixed - except A and G (variables). See attached screen shot please.
Any help will be much appreciated.
Sajid
Product Support
263 Kudos
Post 2 of 2
Re: Customized Content Center
04-09-2012 02:56 AM in reply to: floccipier
Hi Floccipier
Your screenshot seem to come from Autocad. Is your question related to Autocad.
If your question is related to Inventor, you should model one instance of your part. And then go to manage Author, Create Ipart. You will be able to select parameters (select the dimensions you want to drive), then you can create a table with different lines where you assign different values to each of your selected parameters.
Thanks.
Pierre Masson Product Support Specialist PS MFG EMEA Autodesk, Inc.
