Inventor Forum
Customize K factor for sheet metal parts in an assembly
2 REPLIES 2
spsid13
607 Views, 2 Replies
Dear all,
I have an assembly with many sub assemblies which consist of sheet metal parts fo thickness 3mm and 2mm.
I have made a 100 parts with k factor as default but now i am in need of changing the k factor for all the parts according to the following table
Material  thickness  k factor
MS               2             0.46
MS               3             0.4
SS                2             0.42
SS                3             0.38
Can anyone help me with an ilogic or API  here? I would be very grateful.
Sid
Using Inventor 2011
2 REPLIES 2
johnsonshiue
in reply to: spsid13
Hi! I don't think you have to use iLogic in this case. There is a way to propagate the change via Styles Library. You need to set Styles Library to Read-Write in the Project setting. Then make the K-factor change in a sheet metal part. Next, go to Manage -> Styles -> Save. Save back the edited styles to Styles Library. Lastly, start a new assembly and drag and drop those parts into the assembly. Go to Manage -> Styles -> Update. Then all sheet metal files will get the updated styles.
Thanks!
Software Test Engineer
spsid13
in reply to: johnsonshiue
Hi Jhonson,
sorry for the late reply.
In the solution you provided i have to look for all the parts that have bending and then drag and drop each part into an assembly.
Can't this be simplified using ilogic where i just say run rule or run a program and it automatically looks for sheet metal parts and changes these values.
Thanks for your suggestions.
Sid,
Using inventor 2011
