Is there anyway to create a custom weld symbol in inventor? As of right now I am using a sketched symbol from autocad, but i would very much like to get away from this.
I need a bevel weld back gouged then ground flush on the back side. Cant do that as of right now with the inventor.
See if this thread helps you.
http://forums.autodesk.com/t5/Inventor-General/Custom-weld-symbols/td-p/2924658
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
Well, if you are already doing that and I don't know currently of any other way.
Check out this link to an idea I posted speaking to this. Feel free to cast your kudo vote for it.
http://forums.autodesk.com/t5/Inventor-IdeaStation/Ability-to-add-Custom-Weld-symbols/idi-p/4685363
