As far as I know, the only property I can actually define for each individual sheet (for use in iLogic, text fields, etc.) is the sheet name. This is extremely limiting. Each sheet in my drawings has several properties of its own--sheet number (most importantly), what part is ON the sheet, the designer, the revision, etc. I would love to be able to use each of these in labels on the sheet, for example, a text box with "<Sheet #> - <Part> (<Designer>)". The only possible way I could do something like this is to use the sheet number as the Sheet Name, and then use that value in the sheet's text labels, headings, and title block. However, I want to be able to use descriptive names for the Sheet Name, plus that's just one property.
Is there any way I can create and define multiple custom properties for individual sheets? I was exploring the idea of using iLogic, using the ActiveSheet command, possibly, and "tricking" inventor into creating properties for a given sheet. I don't know. Any ideas would be greatly appreciated. Thanks!
If I understand correctly... are you aware that in your titleblock, you can assign model properties as well as drawing file properties to each field? For example, you can have one field pull from the drawing's iproperties, and another pull from the model's iproperties. That way certain values would be the same throughout a drawing series (pulled from the drawing properties), and others could be unique to each individual sheet (pulled from the part or assembly).
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
I hadn't thought of that... I would still rather a sheet have its own embedded properties, but that might work as a work-around. Question: how would I set that up in a drawing template since I don't yet have any views in the drawing? Once I start placing views, say of multiple parts for assemblies, how would Inventor know which part/assembly's properties to use?
If you'd like, please feel free to reference the template I'm working on (attached). I'd like to let the "<Sheet #>" value in the upper-left of my border be a custom, sheet-specific property.
Thanks for the suggestions, Mike. By the way, I should have specified, by sheet number I don't mean "1/11" or something like that. Our sheet numbers are something like 12345-10-01-02, where 12345 is the job number and the rest of the numbers have to do with where the component is in the assembly. So that "sheet number" is not an available property, unfortunately.
I'm going to experiment with your ideas. Thanks for the suggestions. I'm frustrated though that this isn't an option; it seems like this is something that many companies would need, since all sheets in a drawing set pretty much never share ALL the same properties. I'm posting a request for this in the IdeaStation, please do give it kudos and comment if you agree that this would be useful. Thanks!
IdeaStation post: http://forums.autodesk.com/t5/Inventor-IdeaStation/Add-custom-properties-for-sheets-not-entire-drawi...
Nacho
Automation & Design Engineer
Inventor Programmer (C#, VB.Net / iLogic)
Hi Nigel,
Did you already figured it out how to get the sheet specific properties in your sheet? I am struggling with the same kind of issue.
Robbert
Same here. Individual sheet problems would make my life so much easier. On title block to rule them all has it drawbacks sometimes.
Honestly, The easiest is prompted entry. When you start a new sheet it asks for an input. Perfect for naming each sheet something different.
Just add prompted entry into your textbox like you would a property. While it's highlighted type in what you want it called and Boom Sheet title.
what sheet specific properties are you looking for? As already sugested here, you can set up your titleblock to display model properties as well as drawing properties. For example:
filling in Drawing iProperties and adding them to your titleblock will show the same info on all sheets
selecting your model properties instead in your titleblock setup will display the iProperties for the part / assembly
The tool i was referring to wasnt dealing with properties, it was taking a sheet number, drawing no and placing it in the parts list for referral to other drawing packs.
Individual sheets only have Sheet Numbers & Scale as properties as far as i know. You might be able to add attributes (like invisible tags) but im nit 100% if this applies to individual sheets
Sorry i cant be of more help
Nigel
Nacho
Nigel,
Did you ever get that tool developed and debugged? That would be a great feature to have. I have used the macro developed by Brian Ekins here (http://modthemachine.typepad.com/my_weblog/2010/09/balloon-reporting-macro.html but it dumps the data to a text file, from which you can import into a spreadsheet. It works well for spotting the sheet and zone of balloons, but still requires manual input (possible errors) to put the data into the parts list. The method you have described sounds like a better route.
Ken
Hi Ken
yes i have had the tool working for a while now albeit in VBA not as an addin. I do intend to make it into an addin but i just havent had the time yet. I can keep you updated.
The tool works really well though 🙂
Nigel
Nacho
Thanks Nigel. I'm looking forward to trying the tool when you get it finished.
Ken
