Inventor General Discussion
Active Contributor
jasonraul
Message 1 of 3 (147 Views)
custom shapes
147 Views, 2 Replies
06-08-2012 05:01 PM
I made my first custom shape and successfully published it into the Content Centre in my custom section.I have another 10 sizes of the same shape all increasing in size by 5mm.
1. Do i have to create the 10 various sizes individually and publish each 1 to the Content Centre 1 at a time or is there a simpler and quicker way to publish the 10 sizes using the first shape i created?
Best Regards
Jason
Jason,
You need to generate the iparts from the factory file first before you can publish them.
If you open your factory file up and RC and select all of the iparts in the list in the model tree select generate files.
Then you should be able to publish them all at once.
Active Contributor
jasonraul
Message 2 of 3 (133 Views)
Re: custom shapes
06-08-2012 08:53 PM in reply to: jasonraul
I should have mentioned that these will be used in the Frame Generator
Jason
Cadmanto
Message 3 of 3 (127 Views)
Re: custom shapes
06-09-2012 04:21 AM in reply to: jasonraul
Jason,
Best Regards,
Scott McFadden
Inventor Professional 2014
(Colossians 3:23-25)
