Inventor Forum
Custom Properties
2 REPLIES 2
165 Views, 2 Replies
Custom Properties
I have created 2 custom properties in the standard ipt template file (Heat Treatment & Surface Finish). I have set the copy custom properties box and checked the properties to be copied over in the idw template file. Everything works fine if I have the information filled in the custom properties before I start the idw file. Any changes I make in the ipt file after I start the idw file do not follow though to the idw file unless I uncheck and then recheck the copy custom properties box. I don't remember this happening when I first set them up. Is there a switch that I have turned off my mistake or is this the way it is suppose to work. I have read Sean's FAQ on custom properties and everything seems to be set up right.
Ken
Kdale@kadway.com
2 REPLIES 2
This is a bug. You only get 1/2 the
funtionality.
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
I
Ken
Kdale@kadway.com
Thanks. I had been chaseing this for a couple of hours thinking that it was working before. I guess I had never noticed it before.
Ken
