Get to become real good friends with Design Assistant. Read the online help
to get started then this NG for more info.
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
www.sdotson.com/faq.html
"Tim B" wrote in message
news:46A66D2D31E17D024DA66540A2598388@in.WebX.maYIadrTaRb...
> How could I handle the idw drawings that must have a new drawing numbers
> each time.
> "Larry Caldwell" wrote in message
> news:5FD4B1838DCE98D498EFEED63B1C9C0D@in.WebX.maYIadrTaRb...
> > I guess you'd probably have to change the 25 parts! Are you implying
> > that there is an infinite variation of parts, i.e. could be anything
> someone
> > dreams up or is there a limited number of configurations for whatever
goes
> > in and out? If there is a limited number of configurations that are
> > different but similar you could make custom iParts. Other than that you
> > could probably make a template and start with that.
> > ~Larry
> > news:010694D9851E909739E9062EDD8F34A7@in.WebX.maYIadrTaRb...
> > > Looking for advice on how to set up a design for a custom machine. I
> have
> > a
> > > custom machine that has a variable infeed and a variable discharge for
> > each
> > > job release. Basically the machine has a round 100 parts and for each
> job
> > > release about twenty five parts will change each time. The twenty
five
> > > parts will always be different. Any suggestions on how I should do
> this.
> > > Tim
