"rllthomas" <Are
href="mailto:rllthomas@attbi.com">rllthomas@attbi.com> wrote in message
href="news:f14e7da.0@WebX.maYIadrTaRb">news:f14e7da.0@WebX.maYIadrTaRb...
you specifying the part number for each iPart member in your table? If so what
is your syntax?
"rllthomas" <You
href="news:f14e7da.2@WebX.maYIadrTaRb">news:f14e7da.2@WebX.maYIadrTaRb...
can explicitly set in the iPart table the part number, description, and file
name of each instance. You need to do this to get the behavior you are looking
for.
"rllthomas" <OK
href="news:f14e7da.4@WebX.maYIadrTaRb">news:f14e7da.4@WebX.maYIadrTaRb...
what do you mean by custom iPart?
"rllthomas" <Well
href="news:f14e7da.7@WebX.maYIadrTaRb">news:f14e7da.7@WebX.maYIadrTaRb...
I guess maybe you wanted a more elegant solution but just make the part number
a prompted value like the length is.
Now for the next question, am I
the only one that gets a quick exit when I use this in an assembly using
semi-isolated?
Rich Thomas
"rllthomas" <Yes
href="news:f14e7da.9@WebX.maYIadrTaRb">news:f14e7da.9@WebX.maYIadrTaRb...
the file name is a prompted value, but not the part number. Make the part
number property a prompted value and it will correctly populate your
BOM.
"Kirk A." <
href="mailto:karthur@fmi-solutions.com">karthur@fmi-solutions.com>
wrote in message
href="news:9C49FC1815E7FFC0EA32B8EE79ADA69A@in.WebX.maYIadrTaRb">news:9C49FC1815E7FFC0EA32B8EE79A......
These are parts that will allow the user to input
a value (usually length) and the filename. Here is a link for an
example.
href="http://www.cbliss.com/inventor/parts/structural/iChannel-ASTM.zip">www.cbliss.com/inventor/...
Try inserting this into an assembly.
Kirk
"rllthomas" <OK
message
This will make it possible to have a custom property
yet have a regular iPart filename.
How about giving me two excel sheets in the
iPart. One I construct and one that Inventor generates as excel vba routine
(?) when a custom property(ies) is chosen.
This vba excel sheet would have all the first sheet
members plus the custom property(ies) as an regular property(ies) and be "the"
sheet when the filename is generated.
When a second iPart is chosen with a new custom
property, Inventor would read from the constructed sheet and generates another
line in the vba excel sheet.
This should improve iParts quite a bit
Ole Germer
Making a good involute tooth profile possible in
Inventor.
href="http://www.geocities.com/olegermer/index.html">http://www.geocities.com/olegermer/index.html
"Ole Germer" <
href="mailto:germer@sympatico.ca">germer@sympatico.ca> wrote in message
href="news:ACE4E1A99780BB7A408AE681A17EFBCB@in.WebX.maYIadrTaRb">news:ACE4E1A99780BB7A408AE681A17......
Kirk,
Is there an update for the
iChannel? There was an error in that file! Did tell Charles!
Be careful and check the dimensions.
Ole
"Kirk A." <
wrote in message
href="news:9C49FC1815E7FFC0EA32B8EE79ADA69A@in.WebX.maYIadrTaRb">news:9C49FC1815E7FFC0EA32B8EE7......
input a value (usually length) and the filename. Here is a link for an
example.
assembly.
Kirk
"rllthomas" <OK
message
iPart?
