Inventor Forum
Custom Iparts Inv11 SP1
3 REPLIES 3
cory.seifert
246 Views, 3 Replies
When we loaded Inv 11 we noticed the custom Iparts not working like they did in Inv10 when we would bring them into an idw. Now with SP1 loaded they work a little better but still not 100%.
My problem is...
We have a Carr-Lane angle custom Ipart factory that has the different sizes of there standard Carr-Lane angle. Then we will insert this angle into an assy. & create a child & give it a path & filename. We will then proceed to add additional features to it like holes & slots. Before we loaded SP1 we noticed that when we went to create an .idw of this child part it would refence to the factory & not the file we were trying to bring into the idw. After we loaded the SP1 it worked like it should with the exception of not referencing the properties of the child part, it references the properties of the factory. We normally bring in the description, material & 1 custom property into the .idw. This worked in Inv10. Is this still a bug?
3 REPLIES 3
in reply to: cory.seifert
I was able to reproduce the issue that you have mentioned. I will log a
defect and let you know the defect ID.
Are you using the parts list to bring in the properties?
Raj Kumar
Inventor QA
Autodesk,INC.
wrote in message news:5191949@discussion.autodesk.com...
My problem is...
cory.seifert
yes, also what is odd is that the properties show up correctly in a assy bom, but it wont show up correctly in the parts list for just that part. We are currently using a work around by using a sketched symbol & linking the properties that way.
Thanks for the information. I have logged the issue as defect ID 793151 and
sent it to our development team to take a look.
Raj Kumar
Inventor QA
Autodesk,INC.
wrote in message news:5192464@discussion.autodesk.com...
