I was able to reproduce the issue that you have mentioned. I will log a
defect and let you know the defect ID.
Are you using the parts list to bring in the properties?
Raj Kumar
Inventor QA
Autodesk,INC.
wrote in message news:5191949@discussion.autodesk.com...
When we loaded Inv 11 we noticed the custom Iparts not working like they did
in Inv10 when we would bring them into an idw. Now with SP1 loaded they work
a little better but still not 100%.
My problem is...
We have a Carr-Lane angle custom Ipart factory that has the different sizes
of there standard Carr-Lane angle. Then we will insert this angle into an
assy. & create a child & give it a path & filename. We will then proceed to
add additional features to it like holes & slots. Before we loaded SP1 we
noticed that when we went to create an .idw of this child part it would
refence to the factory & not the file we were trying to bring into the idw.
After we loaded the SP1 it worked like it should with the exception of not
referencing the properties of the child part, it references the properties
of the factory. We normally bring in the description, material & 1 custom
property into the .idw. This worked in Inv10. Is this still a bug?
