Inventor Forum
Custom iPart Problem
5 REPLIES 5
mmiller1
174 Views, 5 Replies
Hi Group,
I need to make a custom iPart. I know how to use iParts but I am having trouble with this one. When
I place this custom iPart in my assembly it comes in as "Part3.ipt" which is not the correct name. I
need to name this a part number like 7-55545-002 instead of "Part3.ipt". How can I get the Custom
iPart factory to ask me to "name" the part. I have already made the filename a "key" in the table
but it does not prompt me. What should I do?
5 REPLIES 5
in reply to: mmiller1
AFAIK with custom iParts you cannot specify a
filename.  It will always ask you and will default o the next default part
name (e.g. part1, part2 etc..)
Sean Dotson, PE
href="http://www.sdotson.com">http://www.sdotson.com
...sleep is for the
weak..
Hi
Group,
need to name this
Custom
the way to do it is to add filename in the last
window of the table and add filename
now go to the excel sheet and change the filename
to filename<filename></filename>
that should fix it -- of course you will have to
add the appropriate info in that column
Sean has some good tutorials on the
subject
Hi
Group,
need to name this
Custom
Ole, this works for standard iParts but unless I'm
missing something you cannot specify a filename with Custom iparts (where one
parameter is left to be specified by the user) e.g. one of the structural
channel iparts..
Sean Dotson, PE
...sleep is for the
weak..
subject
Hi
Group,
need to name
the Custom
should I do?
Just to add .... when you place the part in the dialog notice there is a Browse button.
Simply click on it, give your part a name and make sure it is pointed to the right
directory.
Kent
Member of the Autodesk Discussion Forum Moderator Program
"mmiller" wrote in message news:f124db8.-1@WebX.maYIadrTaRb...
> Hi Group,
this one. When
correct name. I
the Custom
the table
> Thanks,
Thanks Kent, I somehow overlooked that and that was one of my biggest beefs
about Custom iParts. Now if I can remember to do that instead of clicking
through so fast.
K
"Kent Keller" wrote in message
news:44F9F0B518B94757B27647963AC0BAD2@in.WebX.maYIadrTaRb...
Browse button.
the right
> directory.
> Kent
> > Hi Group,
trouble with
> this one. When
which is not the
> correct name. I
How can I get
> the Custom
filename a "key" in
> the table
> > Thanks,
