Is there a way to customize the fence labels for detail and section views?
I know we can edit the label directly and add/remove text, but is there way to change the appearance of the label as well, with say a sketched symbol or other graphical representation like a balloon or other customized image?
You can edit the arrow head of a section line, does that sound like what you're looking for?
Thanks, but I was actually looking for something more like what I've attached. I've had a request to customize the labels as shown and include the sheet numbers for the referenced view (ie. Section 3 on Sheet 3).
At this time, there is no support for custom terminators for section view fence labels. I will create a feature enhancement request for you on behalf of this thread. You may also provide feedback directly to the development team via the below link.
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
At this time, work-arounds are the best solution I can offer. Using the 'none' type terminator, you may manually insert custom terminators as a sketch symbol.
Kind Regards,
