Inventor General Discussion
Valued Mentor
BLHDrafting
Message 11 of 14 (383 Views)
Re: Custom Content Centre Shapes and Frame Generator
10-17-2012 02:37 PM in reply to: phils-ams
I can only think that there is something wrong in the publish method. I have published around 80 families to the CC for Structural and all work fine. But I have found that doing it with the iPart/table method (which is a bit more work) has more success than the easier, more straightforward method of creating the parameters, selecting the keys and then using the Structural Shape authoring method.
I'd just try it again. It will eventually work!
Brendan Henderson
Web www.blh.com.au
Twitter @BLHDrafting
Windows 7 x64 -64 GB Ram, Intel Xeon E5-1620 @ 3.6 GHz
ATI FirePro V7800 2 GB, 180 GB SSD & 1 TB HDD, Inv R2013 PDS Premium SP2 Update 3 (Build 200), Vault 2013 Workgroup Update 2 (Build 17.2.9.0)
Active Member
phils-ams
Message 12 of 14 (381 Views)
10-17-2012 02:55 PM in reply to: BLHDrafting
Thanks for that Brendan.... I have some "real" work to go on with for now so I will have to come back to it later... it is probably something I missed in the process. It will be sorted out in time...
Valued Contributor
cmharb
Message 13 of 14 (333 Views)
12-17-2012 01:26 PM in reply to: phils-ams
i have this same error, but im using a part from teh db and not one ive created myself.
the error is:
[WARNING] Frame Generator: Errors occurred during inserting Frame Member(s)
    [WARNING] Insertion of frame member(s) failed
        [ERROR] A frame member could not be created.  The template file for ISO ISO 657/11-1980(E) - Hot rolled steel sloping flange channel sections could not be located in the Content Center library.
as you can see it is a standard iso part.
w7u-64sp1
iv13sp1.1
intel.xeon.e5-2620 0 @2.00 2.00-32gb
gtx560-4g
w7u-64sp1,iv14,intel.xeon.e5-2620 0 @2.00 2.00-32gb,gtx560-4gb
New Member
HrvojeBec
Message 14 of 14 (28 Views)
08-21-2014 06:49 AM in reply to: cmharb
I had same problem I my solution was to remove all text values in fx parameters.
