Inventor General Discussion
Valued Contributor
0 Kudos
Post 1 of 2
Custom Content Center
90 Views, 1 Replies
05-01-2012 10:16 PM
Hi Guys,
I have added a custom shaped C section in Content Center and I got it published but it doesn't ask length. But it works fine with fram generator (changes to length as per the frame skeleton line). I am having problem to understand how I can introduce the length parameter so that I could enter it to desired length whenever required.
Please elaborate. any suitable hyperlink will be hightly appreciated.
Sajid Mahmoopd
*Expert Elite*
841 Kudos
Post 2 of 2
Re: Custom Content Center
05-02-2012 04:10 AM in reply to: floccipier
When you try to insert this piece form Content Center (not in Frame Generator), do you check "As Custom", or leave it "As Standard"?
In this picture, the area where you enter the length is top right.  Choosing Custom will then prompt you to save it as a file somewhere.  Standard will place it in whatever folder you are currently working in, and will automatically name it.
ChrisB / Twitter
Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Thank you! :smileyhappy:
http://cadtipstricks.wordpress.com//
Post to the Community
New Post
