Hi Guys,
I have added a custom shaped C section in Content Center and I got it published but it doesn't ask length. But it works fine with fram generator (changes to length as per the frame skeleton line). I am having problem to understand how I can introduce the length parameter so that I could enter it to desired length whenever required.
Please elaborate. any suitable hyperlink will be hightly appreciated.
Sajid Mahmoopd
When you try to insert this piece form Content Center (not in Frame Generator), do you check "As Custom", or leave it "As Standard"?
In this picture, the area where you enter the length is top right. Choosing Custom will then prompt you to save it as a file somewhere. Standard will place it in whatever folder you are currently working in, and will automatically name it.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
