I have published a content center part and subsequently changed a material and appearance that the part uses within the style library. The problem is the part gets inserted with the original material and appearance. Where is that information stored and why does it not use the info from the style library?
Rob
Rob,
What version of Inventor are you using?
Does this happen for all of your Custom Content Center parts?
If it is one part and you put it in a different assembly, does it come in correctly?
Is it localized to a single project?
Do other users in your organization have the same issue?
Thank you.
Inventor Pro 2014
I have only tried it for a single part.
I have only used it in a single project.
Does not come in correctly in different assembly.
I am the only one in organization using Inventor.
I think one could simply publish a part to content center with an appearance overide and then see that the appearance overide stays when inserting parts even if that appearance is subsequently changed in the style library. (I ended up republishing the part and then redoing all my editing of the CC part.)
