Inventor General Discussion
cmines
Message 1 of 7 (543 Views)
Custom Content Center - boolean user parameter
543 Views, 6 Replies
08-27-2012 01:14 PM
I have added a blank column to a custom content center family table that has a boolean data type.  When I try to map this to a boolean user parameter in the family template using the parameter mapping in the family properties, I get a "Data types mismatch".  In the template this parameter was set to false.  Am I doing something wrong, or is there a trick to getting this mapped correctly?
Thanks!
Employee
jingyi.liu
Message 2 of 7 (533 Views)
Re: Custom Content Center - boolean user parameter
08-27-2012 07:29 PM in reply to: cmines
Could you attach your files here?  It will help to figure out your problem.
Inventor Professional 2015
Jingyi Liu
Quality Assurance Team
cmines
Message 3 of 7 (515 Views)
08-28-2012 07:14 AM in reply to: cmines
I hope these are the files you need.  Please let me know if they aren't.  I didn't know where the xls file for the custom family is kept, so I just did a save as.   I also noticed the labels for the columns I added were missing, so I took a screen shot of the table in Inventor - where they show up
Thanks for your help!
Employee
jingyi.liu
Message 4 of 7 (498 Views)
08-28-2012 10:06 PM in reply to: cmines
Hi Cmines
The reason you missed the label was due to no column caption.
Through the model and  spreadsheet, I almost see your point, there are several boolean type user parameters, you want to map to it.
you can only map a boolean parameter to feature suppression or working feature visibility.
So far, you can only define a numeric type user parameter in your model, and add a integer/real type in family table to map it.
Jingyi Liu
cmines
Message 5 of 7 (488 Views)
08-29-2012 06:01 AM in reply to: cmines
Hi Jingyi Liu,
Thanks for checking in to this.  Just to make sure I understand correctly,  if I have 10 members in a family, for example, that when placed as a standard content center part I need user parameter A to be true and all other members in the family should have user parameter A set to false, it can't be done?  If not, is this a feature that will be added in the future?
Chris
Employee
jingyi.liu
Message 6 of 7 (471 Views)
08-30-2012 08:24 AM in reply to: cmines
Yes, it can't be done so far, you can't map a boolean type parameter in family table to a boolean type user parameter in your content center part.
As a workaround, you can define a numeric type user parameter (unitless) in part, and define a integer/real parameter in family table and assign its value 0 or 1.
I will log it as a wish.
Jingyi Liu
cmines
Message 7 of 7 (468 Views)
08-30-2012 08:35 AM in reply to: cmines
Thank you so much for your help and suggestion!  I will give it a try.
