I have attached our custom title block template that we use daily. My issue is that I am currently developing drawings and i cannot select anything on my drawing to balloon the different items unless the border is not inserted on the sheet.
I am wondering is there is a problem with our custom border template but have no clue what it could be. Has someone run across this issue are know of anything I can do to fix it.
Thanks Derek
Thanks Derek
Welcome Derek,
Note to others: this is IV 2014.
Can you also post a file that has some parts in it for ballooning so people can see what is happening? Maybe just a small assembly with 2 parts in it. If so, remember to do a pack n go so you get the whole thing including the part files.
Mentioning the version you use is always a good idea since people in this forum are using so many different versions, you're more likely to get help from the righ people. Good luck.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
I was able to open your drawing.. insert the border.. place an iam file base view and balloon without any issues.
I was also able to open the template insert a border and create views and balloon them with a single balloon as well as auto balloon. Taking it one step further I created a new sheet left it blank and was again able to insert and balloon a assembly.
Have you tried a different file to see that it is not assembly file specific?
