Inventor Forum
Curving edges of shape like a circle
5 REPLIES 5
Jonahk
293 Views, 5 Replies
Hi, so I need to curve the edges of this shape to appear as if they're being constrained by a circle, and I'm not sure how to do this.  The model I created is attached at the bottom.  The model I'm trying to build has a listing of R = 2.50, but I've tried every filleting option there is, and nothing is working quite right.  Any help would be greatly appreciated.
5 REPLIES 5
JDMather
in reply to: Jonahk
Do you have some sort of reference image or url?
First thing I notice is that your Sketch1 is not constrained and you have a bunch of unnecessary duplicated dimensions.
I recommend you start here -
http://home.pct.edu/~jmather/SkillsUSA%20University.pdf
http://inventortrenches.blogspot.com/p/inventor-tutorials.html
CCarreiras
in reply to: Jonahk
Hi!
Something like that?
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
CCarreiras
Jonahk
in reply to: CCarreiras
Thanks a lot for the quick replies.  The solution is supposed to look something like this:
http://puu.sh/bqyS6/5d539652bb.jpg
As you can see in the bottom right, it gives a value of R=2.5, and I'm not sure what that value represents or how to implement it.  And yes, I am new to inventor.
JDMather
in reply to: Jonahk
Extrude circle through all with the Intersection option.
CCarreiras
in reply to: Jonahk
Hi!
CCarreiras
