Inventor General Discussion
Active Contributor
0 Kudos
Post 1 of 6
Curved tube or pipe
867 Views, 5 Replies
10-25-2012 06:42 AM
Can Anyone tell me how to construct a curved tube/pipe run?
I spent hours on this and it's beyond my limited knowledge.
I've created a 3d sketch with the run of the tube on it but when I click "Derived Route" although the full 3d sketch is highlighted bugger all happens. There's nothing in the "Included Geometry" folder.
Is it because of the material? I've set it to a "Tube With Bends" and set my default radius.
Inventor 2013
Employee
36 Kudos
Post 2 of 6
Re: Curved tube or pipe
10-28-2012 08:15 PM in reply to: sbromley
Did you try Frame Generator, which can generate curved tube or pipe as well? Not sure if it works for your case.
Nicolas Xu
Sr. SQA Eng.
Fusion 360 Quality Assurance Team
Autodesk, Inc.
Distinguished Contributor
4 Kudos
Post 3 of 6
12-19-2013 06:03 AM in reply to: sbromley
is it possible to do it in 2014?
(curved rigid pipe in tube and piping)
*Expert Elite*
864 Kudos
Post 4 of 6
12-20-2013 05:27 AM in reply to: richiesuk
As far as I know Tube & & Pipe requires an elbow or branch type fitting at any bend in a rigid pipe route.  Flexible tubing will do such a thing, for example bent copper tubing.  I have never tried this, but I assume you could create a pipe style of nearly any diameter and material.... and as long as it is defined as a "bent tube" style (or whatever Inventor calls it), it would at least emulate a curved rigid pipe route.
Interesting, if I have some time later maybe I'll play around with that.
ChrisB / Twitter
Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Thank you! :smileyhappy:
http://cadtipstricks.wordpress.com//
4 Kudos
Post 5 of 6
12-20-2013 05:57 AM in reply to: sbromley
I need curved lines 180degree+
please see atached picture.
Any Autodesk comment on this pls??? :cathappy:
Richard
*Expert Elite*
776 Kudos
Post 6 of 6
12-20-2013 01:45 PM in reply to: richiesuk
I would just do a Sweep
IV2015 SP1-ud2 PDSU / Sim Mech 2015 r1 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-980 Classified - 347.09
SpacePilot Pro 10.2.0 / 17.2.0.11011 / 4.17
Delta Tau Chi ΔΤΧ
Post to the Community
New Post
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
