Can Anyone tell me how to construct a curved tube/pipe run?
I spent hours on this and it's beyond my limited knowledge.
I've created a 3d sketch with the run of the tube on it but when I click "Derived Route" although the full 3d sketch is highlighted bugger all happens. There's nothing in the "Included Geometry" folder.
Is it because of the material? I've set it to a "Tube With Bends" and set my default radius.
Did you try Frame Generator, which can generate curved tube or pipe as well? Not sure if it works for your case.
@richiesuk wrote:
is it possible to do it in 2014?
(curved rigid pipe in tube and piping)
As far as I know Tube & & Pipe requires an elbow or branch type fitting at any bend in a rigid pipe route. Flexible tubing will do such a thing, for example bent copper tubing. I have never tried this, but I assume you could create a pipe style of nearly any diameter and material.... and as long as it is defined as a "bent tube" style (or whatever Inventor calls it), it would at least emulate a curved rigid pipe route.
Interesting, if I have some time later maybe I'll play around with that.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
I need curved lines 180degree+
please see atached picture.
Any Autodesk comment on this pls???
Richard
