I make 2 simple parts and placed in an assembly file.Could someone please show me how to make the following
1.Curved Spring with the ends flat so as to sit flush on the 2 parts
2. Spring sits on the base over the mount and between the circle on the top part
The angle is 1.39deg
The files are Inventor 2014
Regards
Dave
Solved by CCarreiras. Go to Solution.
I would use the Bend Part command after using Coil and "grinding" the flats.
Can you attach your attempt here?
Hi JD
I only could get this far.Can you show how to Bend (Bend Tool Commend) this part so as it fits between the 2 parts in post 1?
Carlos,
Thank you for very good part.I will see now how you make
Regards
Dave
I make a bend in the spring with Bend Tool.I noticed a deformation in the middle of the spring.How do i fix this?
I place Bent spring in assembly and see interference at top.How do i now fix this?
Have i used this command correctly or where have i got it wrong?
Regards
Dave
HI!
Cut the spring in the end of the process, using the surfaces of the other two parts.
The lines in the middle, it's normal, we can't fix it.
To avoid all this, check my case example, more work, but perfect shape.
Hi Carlos
thanks for the help.....i agree your modelled part is very well done
Best Regards
Dave
I am looking at doing something similiar to your solution in Post#3 regarding the spring
A couple of questions please
1. Did you create the spring while in assembly mode?
2. How did you create the Surface 1 and Surface 2 references?
3. How did you get the 2 dimensions in the sketch-1 ?
Cheers
James
2014
Hi!
1 - Yes, some work as to be made in assembly context.
2 - The surfaces are copys taken from other two part's faces. (In the assembly context)
3 - Arc perpendicular between the two surfaces.
Hi
I started with create Part in Assembly mode and saved the part to folder
1. I projected 2 lines (green)
2. Then i placed a vertical Line
How do i perform the following?
How do i now create the Arc
How do i get those 2 surfaces (reference 1 & 2)
What version you are using.
You copy wrong surface on top, you have better info if you copy the inner circle.... but tha's ok, you can proceed.
you dont need sketch 2 and 3, delete it
The arc must be perpendicular with the lower projected line, place this constrain.
Hi Carlos,
I just changed the shape of the original posters files.
I have the surfaces done in the spring part file....please how do i proceed from here
James
Hi!
It's hard to explain all by words, so check the video and try to do it.
https://dl.dropboxusercontent.com/u/108503790/spring_1.mp4
After create the surface who will guide the spring (previous video), we create some auxiliary geometry to guide the spring dimensions:
https://dl.dropboxusercontent.com/u/108503790/spring_2.mp4
Now you create a 3D sketch with the spring path. Pay attention to the required auxiliary geometry to fix the spring geometry.
https://dl.dropboxusercontent.com/u/108503790/spring_3.mp4
Hi!
Now the final step, the solid spring:
https://dl.dropboxusercontent.com/u/108503790/spring_4.mp4
Hi
Excellent instructional videos.Thank you for help
Did not know you could make a curved spring this way to fit between 2 parts
Cheers
James
