Hello.
When I try to get the curvature analysis it simply disapears when I try to change the view or zoom. I picked up few sec ago that it dosn't even show up.
Do you have any idea how to fix this?
Solved by scottmoyse. Go to Solution.
I suspect that this is a problem with your graphics card settings?
I haven't seen this problem before, so I've referred it to @Autodeskhelp.
Those guys are awesome, I'm sure that they can help!
Have you tried turning off some of the options on the View tab? Try changing between view styles, and maybe turning off shadows etc.. Does it still happen then?
Also On the hardware tab in Application Options, try each setting in there one by one. Make sure you close all open Inventor files before making the change, otherwise it won't actually change anything... or close them all after changing it. The next time you open a file it will apply the new setting from the Hardware tab.... does it still disappear with Software Graphics selected?
Scott Moyse
Design & Manufacturing Technical Services Manager at Cadpro New Zealand
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
What version of Inventor?
Have you installed all Service Packs and Updates?
