I tried to assymble pipe in Inventor 2015 (created as ipt) over another pipe crosswise and tieing both together by a bolt through a hole in both pipes and how to costrain the surfaces of the pipes over each other and aligne them through holes in both pipes.
Thank you
Ata Jabbar
Solved by mflayler2. Go to Solution.
Can you attach your assembly here?
@atajabbas wrote:
Hello,Thank you for your reply.Attachment is my assymbly file for crossing pipes and boltsMu regards,Ata J. Abbas
There is nothing attached.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Try creating an extruded surface from the contour of the hole cut into the pipe.
Use this surface to constrain to the other pipe.
Make the radius of the surface equal to half the outside diameter of the crossing pipe.
An IAM is nothing without the link linked parts. Attach a ZIP of the IAM and the IPTs used in your design.
Mark Flayler - Engagement Engineer
IMAGINiT Manufacturing Solutions Blog: https://resources.imaginit.com/manufacturing-solutions-blog
I tried this before, but the costraint of the pipes is fixed to the new surface and it remaines as part of the project
Inside the Pipe files....
Create a Work Axis through the holes. You can then use a Mate Constraint in the IAM to line these up
Create 2 Work Planes using the Parallel to Plane and Tangent to Surface option on the top of the pipe and bottom of the pipe with the XY plane as your reference plane - Use Mate constraints in the assembly to put them together.
After this you just have to lock your rotation down which you can do with an Angle constraint or another Mate constraint to origin planes of the parts or assembly.
See if this helps.
Here is an Assembly of what I was trying to show you.
The planes are Mated just fine along with the Axis. You just need to lock the rotation with another constraint.
If you add a washer, bolt, nut or anything else just use the planes and axis to constrain to.
