I'm making two section views of a large assembly. One view works just fine, the other does not. The attached pdf shows the issue.
I can turn off the hatch & hide the bounding border, but view E is only showing the cut face.
Any suggestions?
Solved by coreyparks. Go to Solution.
In my experience weird things like this are usually caused by a corrupt part. I would start by saving where you are at and then delete a handful of parts from your assembly and see if the view changes. Continue to do this until you find a group of parts that, when deleted, fix the problem. Undo that and start deleting parts from the last group one at a time until you find the part with the issue. Then open that part and do a rebuild all and see if this might fix the problem. If the offending part turns out to be something imported from a step, sat, etc. then you may need to redraw from scratch to fix the problem.
