Inventor Forum
crosshatch issue
1 REPLY 1
eveylynne
2142 Views, 1 Reply
crosshatch issue
I'm making two section views of a large assembly. One view works just fine, the other does not.  The attached pdf shows the issue.
I can turn off the hatch & hide the bounding border, but view E is only showing the cut face.
Any suggestions?
1 REPLY 1
coreyparks
in reply to: eveylynne
In my experience weird things like this are usually caused by a corrupt part.  I would start by saving where you are at and then delete a handful of parts from your assembly and see if the view changes.  Continue to do this until you find a group of parts that, when deleted, fix the problem.  Undo that and start deleting parts from the last group one at a time until you find the part with the issue. Then open that part and do a rebuild all and see if this might fix the problem.  If the offending part turns out to be something imported from a step, sat, etc. then you may need to redraw from scratch to fix the problem.
Please mark this response "Accept as solution" if it answers your question.
Corey Parks
