Inventor General Discussion
Distinguished Contributor
SKinzel
Message 1 of 11 (1,647 Views)
Cross Hatch
1647 Views, 10 Replies
08-24-2012 02:44 PM
I have an assembly that is made up of steel and brass parts.  I have assigned the material in each part but when I cross section the assembly in a drawing all sections use the ANSI32 section style.  I can't find a way to tell Inventor to use a cross hatch based upon the part material.  Am I blind or is this not possible?
Stuart Kinzel
Inventor 2013-64bit, HP EliteBook8740w Intel Core i5CPU 2.67 GHz
8GB memory
Windows 7 64bit
Hi Kinzel,
Please ues Style Editor for cutomerize for the first time or save the style to a template, then you could get the hatch by materials assigned.
Steps:
1. Open Style Editor in a blank Draing.
2. Select the Stardard style which in use.
3. Tab "Material hatch patten default" to change the Default hatch for each Material.
4. Save the style.
blair
Message 2 of 11 (1,642 Views)
Re: Cross Hatch
08-24-2012 03:13 PM in reply to: SKinzel
Just RMB on the hatch and select "Edit", select the appropriate material from the Pattern drop-down menu.
Not b\y default, you must make the change yourself. All you get is the ability to select the default Hatch from the Styles Manager.
IV2015 SP1 PDSU / Sim Mech 2015 r1 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-690 Classified - 340.52
SpacePilot Pro 3.17.7, 6.17., 4.11
SKinzel
Message 3 of 11 (1,638 Views)
Re: Cross Hatch
08-24-2012 03:16 PM in reply to: blair
That is what I ended up doing but it seems to me that if I assign a material to an IPT then the cross hatching of a drawing should recognize that and use that as a basis for what cross hatch pattern is used.  I was just suprised that Inventor doesn't seem to be able to determine what cross hatch pattern to use based upon the material property.
Stuart Kinzel
8GB memory
Windows 7 64bit
Employee
Xun.Zhang
Message 4 of 11 (1,612 Views)
Re: Cross Hatch
08-26-2012 10:45 PM in reply to: SKinzel
Hi Kinzel,
Steps:
4. Save the style.
Xun Zhang
Software QA Engineer
Inventor Quality Assurance Team
SKinzel
Message 5 of 11 (1,594 Views)
Re: Cross Hatch
08-27-2012 05:11 AM in reply to: SKinzel
Thank you.  This is what I was looking for.  I am a little suprised that this isn't set up as default so that different materials will use the "defined" cross hatch patterns.
Stuart Kinzel
8GB memory
Windows 7 64bit
Valued Contributor
Mike686
Message 6 of 11 (1,507 Views)
Re: Cross Hatch
11-09-2012 08:26 PM in reply to: SKinzel
hi, i've been wondering if there's a way to tell inventor to place the angle of an hatch patern parallel to a line..
i'm doing glass panel and when i do a section of it i wish to see the line parallel to the panel
i want the result to look like the pdf file i've joint
is it possible and if yes how would i do that
Product Design Suite 2013
JDMather
Message 7 of 11 (1,491 Views)
Re: Cross Hatch
11-10-2012 05:45 AM in reply to: SKinzel
Are you assigning Materials (physical properties) or are you assigning colors/textures with material names?
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
SKinzel
Message 8 of 11 (1,432 Views)
Re: Cross Hatch
11-16-2012 02:29 PM in reply to: JDMather
In 2013 I open the Material Browser and assign a material to the model.  I've assigned different colors to different matierals to help me easily remember what is made out of what.  Plus, looking at a monochrome assembly model is boring.  I just thought it was a little strange that by default Inventor seems to use the ANSI 32 hatch pattern for almost all of the materials.  On a drawing one of the quickst and easiest ways to differentiate materials is by their cross hatching.  Inventor 2011 was the same as I recall.
I was taught that the hatch pattern for steel looked like ANSI 32 and that aluminum (ANSI 38), iron (ANSI 31) and other materials used other patterns.  Maybe that isn't specified in any actual, official drafting standard?  My drafting classes have been so long ago that maybe I am misremembering and I just incorporated one company's rule of thumb into my personal preferences.
Stuart Kinzel
8GB memory
Windows 7 64bit
blair
Message 9 of 11 (1,426 Views)
Re: Cross Hatch
11-16-2012 03:04 PM in reply to: SKinzel
If you check the Styles Manager, you will find that someone at Autodesk has ANSI31 set for all the material (I hope that this was an oversight or possibly some programmers last work day at Autodesk).
Win7-64
Active Member
blissmx
Message 10 of 11 (401 Views)
AutoCad Auto hatching based on layer or material
06-13-2014 12:37 PM in reply to: Xun.Zhang
Is there a way to do this in AutoCad 2013?
I have a 3D model made of Alumn, Steel, Glass and MDF...
When using the layout command and creating cross sections from my model, is there a way to assign a hatch to a material (or layer) so when I creat a cross section, the hatch patterens are assigned based on the layer they are on, or the matterial that is assigned to that layer?
At the moment, all layers and materials are using the same hatch. I don't want to go through my entire drawing package and moidify each individual hatch.
Help...
Please....
-Ben
