Inventor General Discussion
Distinguished Contributor
10 Kudos
Post 1 of 9
Cross hairs left over from bolted connections
379 Views, 8 Replies
08-01-2012 09:29 AM
When deleting bolted connections from my assembly using design accelerator I am left with black cross hairs where the connections used to be, I can't seem to delete these from my model either in the assembly itself or by editing the sketch, what are these, why are they left over from a deleted connection and how do I remove them  ... ? ? Please can someone help ? Thanks
Anthony Goodwin ~ Cad Manager/Senior Designer
Autodesk Inventor Professional 2013 SP2 64-Bit Edition
Windows 7 HP Z400, Intel Xeon W3550 3.07GHz
12.0GB RAM, ATI FirePro V4800 (FireGL)
869 Kudos
Post 2 of 9
Re: Cross hairs left over from bolted connections
08-01-2012 09:30 AM in reply to: Anthony
Can you post a screen shot?  I'm not sure what these could be.
ChrisB / Twitter
Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Thank you! :smileyhappy:
http://cadtipstricks.wordpress.com//
10 Kudos
Post 3 of 9
08-02-2012 02:03 AM in reply to: cbenner
Please see attached screen shot of the leftover cross hairs.
869 Kudos
Post 4 of 9
08-02-2012 08:32 AM in reply to: Anthony
These look like sketch points.  Is there a sketch in one of your parts that has the visibility turned on?
ChrisB / Twitter
403 Kudos
Post 5 of 9
08-02-2012 06:15 PM in reply to: cbenner
The points are leftover from when a Bolted Connection was made that had to cut the holes into the assembly children. If you go to the child part and delete the hole (shown with a lock symbol from memory) this is when the points are left in the part. There doesn't seem to be a skecth to delete them from. Sometimes they are deleted and sometimes not. Often I just turn sketch visibility off. Sorry I have no perfect answer. If you get 1 let me know. I've been arguing with these things for years!
Brendan Henderson
CAD Manager
New Blog | Old Blog | Google+ | Twitter
Inventor 2014 PDS Premium SP2 Update 2, Vault Professional 2014 Subs Release 1 & Update 1, Win 7 64 bit
Please use "Accept as Solution" & give "Kudos" if this response helped you.
403 Kudos
Post 6 of 9
10-08-2012 01:52 PM in reply to: brendan.henderson
I have a solution for this to delete them, but not a permanent fix.
Edit the point sketch, then create a rectangle and extrude it, then delete the extrusion. It would remove the sketch too. Have to do this for each point.
Brendan Henderson
CAD Manager
10 Kudos
Post 7 of 9
10-09-2012 04:22 AM in reply to: brendan.henderson
Hi, thanks for this fix, I will try this on the model I am working on, I have quite a few of the crosshairs on the design so I may need to do this for every point like you suggested. Thanks again
2,129 Kudos
Post 8 of 9
10-09-2012 04:45 AM in reply to: Anthony
I'm sure there is an easier way - attach your assembly here.
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
Active Member
0 Kudos
Post 9 of 9
10-16-2014 03:45 AM in reply to: JDMather
I see this is an old post,
but just in case it hasn't been answered elsewhere:
You can usually right click these crosshairs and select "Edit sketch" and then delete the point.
There is one sketch per point, but they don't appear in the feature browser.
