Inventor Forum
Welcome to Autodeskā€™s Inventor Forums. Share your knowledge, ask questions, and explore popular Inventor topics.
Showing results forĀ
Did you mean:Ā
Cross hairs left over from bolted connections
8 REPLIES 8
Message 1 of 9
620 Views, 8 Replies
When deleting bolted connections from my assembly using design accelerator I am left with black cross hairs where the connections used to be, I can't seem to delete these from my model either in the assembly itself or by editing the sketch, what are these, why are they left over from a deleted connection and how do I remove them  ... ? ? Please can someone help ? Thanks
8 REPLIES 8
Message 2 of 9
cbenner
Message 3 of 9
in reply to: cbenner
Please see attached screen shot of the leftover cross hairs.
Message 4 of 9
cbenner
Message 5 of 9
brendan.henderson
The points are leftover from when a Bolted Connection was made that had to cut the holes into the assembly children. If you go to the child part and delete the hole (shown with a lock symbol from memory) this is when the points are left in the part. There doesn't seem to be a skecth to delete them from. Sometimes they are deleted and sometimes not. Often I just turn sketch visibility off. Sorry I have no perfect answer. If you get 1 let me know. I've been arguing with these things for years!
Brendan Henderson
CAD Manager
New Blog | Old Blog | Google+ | Twitter
Inventor 2016 PDSU Build 236, Release 2016.2.2, Vault Professional 2016 Update 1, Win 7 64 bit
Please use "Accept as Solution" & give "Kudos" if this response helped you.
Message 6 of 9
I have a solution for this to delete them, but not a permanent fix.
Edit the point sketch, then create a rectangle and extrude it, then delete the extrusion. It would remove the sketch too. Have to do this for each point.
Brendan Henderson
CAD Manager
Message 7 of 9
in reply to: brendan.henderson
Hi, thanks for this fix, I will try this on the model I am working on, I have quite a few of the crosshairs on the design so I may need to do this for every point like you suggested. Thanks again
Message 8 of 9
JDMather
I'm sure there is an easier way - attach your assembly here.
Message 9 of 9
jls
in reply to: JDMather
I see this is an old post,
but just in case it hasn't been answered elsewhere:
You can usually right click these crosshairs and select "Edit sketch" and then delete the point.
There is one sketch per point, but they don't appear in the feature browser.
