Hi, I am new to Inventor 2014 and I am trying to do two things. First I would like to connect the Cylindrical part to the Washer part. If you notice there is a hole between them and I want a 2 dimensional circle to connect the two only at the part where they meet. (Picture 1)
Secondly I am trying to make these two circles be the same distance from eachother as the first two circles. What I did was make the sketch and then emboss/engrave it onto the cylinder. I tried calculating circumference and solving it mathematically what length the lines should have but it's not giving me the expected results. (Picture 2)
Thank you.
Solved by CCarreiras. Go to Solution.
HI!
First, you want to connect the cylinder to the washer, but... Without Thickness!! ??
Second, are you sure that you want the holes like that (Internally they are kind of "oval")
Also, it's better have the sketch constrained.
Answer me, and then i can direct you for a better aproach.
Did you find this reply helpful ? If so, use the Accept as Solution or Kudos - Thank you!
Hi!
So, you don't know too much about Inventor. I'll try to help.
Do you want that i made a video showing how to crete this part?
You have to learn more, make some tutorials, you can find them in Inventor Help.
I have no real idea of your true design intent - but here is an alternative example. (are you working from a book or some other reference?)
It is all in the feature history tree.
Ok I was able to figure it out with by referencing your work and a lot of trial and error. Thanks for the help.
This is not from a book, this is from an object I am trying to recreate.
Being you appear to be missing even the simplest concepts and teminology you might want to go through some of the tutorials and the getting started section to become more familiar with the software.
In case you should like to see yet another approach.
