Inventor Forum
creating sub-assembly files
9 REPLIES 9
Message 1 of 10
rajeshindi
3895 Views, 9 Replies
I am working mostly on assembly files.  Once I create so many parts, I want to put few of those parts together and create many sub assemblies.  So that I can switch on and off the visibility while working with other parts.
Any help?
9 REPLIES 9
Message 2 of 10
mcgyvr
in reply to: rajeshindi
ok.. What do you need help on? A subassembly is just a regular assembly that gets placed into another assembly file.
You can also select multiple parts and demote to create a subassy on the fly.
Message 3 of 10
PaulMunford
A quick way to create a subassembly is to select all the parts and hit the TAB key. Or you can right click and chose 'Components' 'Demote'...
Autodesk Industry Marketing Manager UK D&M
Opinions are my own and may not reflect those of my company.
Linkedin Twitter Instagram Facebook Pinterest
Message 4 of 10
RyanBotha
in reply to: PaulMunford
Yeah, that normally works well. Just click 'n drag the resulting assembly, as they sometimes loose constraints. I always try double check within the sub-assembly too, make sure everything is tight.
Message 5 of 10
rajeshindi
in reply to: mcgyvr
It works.  Thanks.
Message 6 of 10
rajeshindi
How to add an existing part in to an existing sub assembly.
Thanks in advance.
Message 7 of 10
PaulMunford
Just drag and drop...
Message 8 of 10
Farsad_BKH
HI
I want to insert some design accelerator components in a sub assembly I,ve created befor in my assembly. But it doesn't dragged in my sub assembly !!!
Also I want to insert my bolted connections or pattern components in my sub assemblies.
How can I do that?
Help me pls ...
Thank you
Message 9 of 10
PaulMunford
in reply to: Farsad_BKH
Bolted connections work slightly differntly. The best thing to do is create them at the subassembly level where you want them to reside...
Message 10 of 10
Farsad_BKH
Thank You alot, But what about Design accelerator components??? like shaft, bearing and .....
Is there any way for them or should design them in sub assembly level at first???
