I am working mostly on assembly files. Once I create so many parts, I want to put few of those parts together and create many sub assemblies. So that I can switch on and off the visibility while working with other parts.
Any help?
Solved by mcgyvr. Go to Solution.
ok.. What do you need help on? A subassembly is just a regular assembly that gets placed into another assembly file.
You can also select multiple parts and demote to create a subassy on the fly.
Yeah, that normally works well. Just click 'n drag the resulting assembly, as they sometimes loose constraints. I always try double check within the sub-assembly too, make sure everything is tight.
How to add an existing part in to an existing sub assembly.
Thanks in advance.
HI
I want to insert some design accelerator components in a sub assembly I,ve created befor in my assembly. But it doesn't dragged in my sub assembly !!!
Also I want to insert my bolted connections or pattern components in my sub assemblies.
How can I do that?
Help me pls ...
Thank you
Thank You alot, But what about Design accelerator components??? like shaft, bearing and .....
Is there any way for them or should design them in sub assembly level at first???
