Inventor General Discussion
Member
jason
Message 1 of 9 (853 Views)
Creating sheetmetal flanges on cut angles
853 Views, 8 Replies
09-22-2011 07:33 AM
I am trying to create flanges on the inside of a cut angle from a contour flange based drawing see attached file.  I am not able to get the flanges to attach since the material thickness varies due to the cut.
Distinguished Mentor
rdyson
Message 2 of 9 (840 Views)
Re: Creating sheetmetal flanges on cut angles
09-22-2011 09:20 AM in reply to: jason
First, learn to completely constain your sketches to avoid problems later.
Then use Cut Across Bend
Then you will be able to add your flanges
JDMather
Message 3 of 9 (836 Views)
09-22-2011 09:37 AM in reply to: rdyson
Uhmmm, I don't think that will result in the correct geometry.Cut across bend.pngCan you attach your solution here?
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
JDMather
Message 4 of 9 (833 Views)
09-22-2011 09:47 AM in reply to: jason
jason,
If you model with obvious symmetry about the origin and use geometry constraints like equal = and colinear you can use far fewer dimensions to control your model.
You might read this document http://home.pct.edu/~jmather/Symmetry.pngskillsusa%20university.pdf
JDMather
Message 5 of 9 (810 Views)
09-22-2011 11:18 AM in reply to: JDMather
Try this one.
Member
jason
Message 6 of 9 (807 Views)
09-22-2011 11:23 AM in reply to: jason
Thank you for the help I get the same issue following your example.  I am trying a few things to get the plane to cut straight across and not down so it cuts on a 45 straight across on the left and right side.
Active Member
jeff
Message 7 of 9 (806 Views)
09-22-2011 11:25 AM in reply to: JDMather
Hi! Here is another way that I tried to add flanges to a sloped edge. See attached file.
Inventor Pro 2015 RTM Update 2
Windows 7 64-bit 12G RAM
Dell Precision T3500
Nvidia Quadro NVS 295
Valued Contributor
eman6398
Message 8 of 9 (745 Views)
09-23-2011 09:05 AM in reply to: jason
I have done a few things like this using a surface then using the thickening comand. to make sure it is completely flat.
Dell t1500 i7 8 gb ram
Windows 7 64 bit
ati firepro v4800
Valued Contributor
eman6398
Message 9 of 9 (741 Views)
09-23-2011 09:08 AM in reply to: eman6398
well almost completely flat.
Windows 7 64 bit
ati firepro v4800
