Inventor Forum
Welcome to Autodeskā€™s Inventor Forums. Share your knowledge, ask questions, and explore popular Inventor topics.
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
Creating PDF's
5 REPLIES 5
KevinPinks7697
438 Views, 5 Replies
Creating PDF's
I often use the built-in PDF creator in Inventor 2013. My only complaint is that for a multi-sheet drawing, I have to keep going into "options" and selecting "all sheets". Is there a way to set this as the default?
5 REPLIES 5
QuasiMojo
in reply to: KevinPinks7697
I wish!
Make an Ilogic code for printing the pdf's There are sample codes thru out the boards for making it print one, I'm sure it can be made to print all
Mike Davis
You could employ another method, such as using the Task Scheduler. Attached is a document on using TS and PDF Creator. 1 bonus of using the TS is that you can create the PDF's for a whole directory of drawing files.
Brendan Henderson
CAD Manager
New Blog | Old Blog | Google+ | Twitter
Inventor 2016 PDSU Build 236, Release 2016.2.2, Vault Professional 2016 Update 1, Win 7 64 bit
Please use "Accept as Solution" & give "Kudos" if this response helped you.
4donwan4
Consider posting this in the Ideas forum for it to be considered for a future release.
Don
