I often use the built-in PDF creator in Inventor 2013. My only complaint is that for a multi-sheet drawing, I have to keep going into "options" and selecting "all sheets". Is there a way to set this as the default?
Solved by brendan.henderson. Go to Solution.
You could employ another method, such as using the Task Scheduler. Attached is a document on using TS and PDF Creator. 1 bonus of using the TS is that you can create the PDF's for a whole directory of drawing files.
Consider posting this in the Ideas forum for it to be considered for a future release.
Don
Don
Existing, related IdeaStation ideas:
http://forums.autodesk.com/t5/Inventor-IdeaStation/Idw-to-PDF-default-setting/idi-p/4779191
I hope this helps.
Curtis
