Prefereably in a sketch, I would like to place points along a curve (specifically, in my case, along a quarter of an elipse) equidistant to each other (with a point on each end of the curve). As I change the size of the curve, the points automatically space themselves accordingly.
The solution does not have to be in a sketch, but that would be my preference.
Anyone know of a direct command or solution to do this?
Thanks.
Hi!
You can do this easilly with construction points doing a pattern as "Curve length".
You can use these points as associative projected geometry in a sketch.
Check the video i made for you.
https://screencast.autodesk.com/Main/Details/c22f630d-9b00-41f0-b7c6-fddf2a26f066
Did you find this reply helpful ? If so, use the Accept as Solution or Kudos - Thank you!
