Inventor General Discussion
Valued Contributor
0 Kudos
Post 1 of 4
Creating Dimensions on sketch
198 Views, 3 Replies
12-17-2012 08:11 AM
Hi all
One of our senior designers seems to think there is a setting when creating a sketch that will automatically dimension.
So if a straight line is draw and 5 mm length is entered a 5 mm line will immedialtey be created, he seems to think that you can then immedialtey Dimension said line??
I can't find anything, settings wise, but he is a switched on guy so just wondered if there is any truth to his claim?
Gareth
As JD said.
App options, Sketch, Heads-Up Display, Create Dim's
2,132 Kudos
Post 2 of 4
Re: Creating Dimensions on sketch
12-17-2012 08:36 AM in reply to: Stemdriller
What version of Inventor are you using?
For the past few releases you can enter the dimensions directly as you are creating the sketch.
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
Distinguished Mentor
139 Kudos
Post 3 of 4
12-17-2012 09:00 AM in reply to: Stemdriller
As JD said.
Valued Contributor
0 Kudos
Post 4 of 4
12-18-2012 12:16 AM in reply to: rdyson
Thank you to both for your responses.
That is just what we was looking for.
Thanks again
GW
