How do you mate two surfaces so that the item will not move any further once it makes contact with that surface? i.e a rotating cam which is designed to stop once it comes into contact with an object/surface
Please Help!
Solved by JDMather. Go to Solution.
Contact Sets
Contact Solver
or
if you have Pro use Dynamic Simulation.
Attach your assembly here.
We have a tutorial of how you can create contact set for a number of objects and activate the contact solver in order to detect the contact between these bodies.
