I think he was talking to *hdd, at the end of *hdd's message he put his name, Rick. However your perfectly fine and did not make any rude/snide comments.
The method of adding an axis works, but why doesn't autodesk just fix the issue and make the automated centerlines command recognize arcs?
I would be happy if I could just use the standard centerline tool, but I have yet to find a use for that tool. The bisector at least is usefull for adding centerlines in side views of holes, the other one serves no purpose that I can see. I also whishthey would allow you to edit the amount a centerline arc extends past the end of a curve. The centerline should not ectend past the point where an arc and a straight line intersect.
