Inventor Forum
Creating Boundary Patch
4 REPLIES 4
djchristophe
1556 Views, 4 Replies
Guys,
I'm having problems creating a boundary patch on the attached model, Its a Y-Pipe joint in 3 planes that I'm attempting to split in half. I've used a silhouette curve to create a centre line in a 3d sketch then joined the ends together, however when I try to select the lines to create the boundary patch it only allows me to select some not all of the lines.
Can any one advise please?
Chris
4 REPLIES 4
JDMather
in reply to: djchristophe
Is this what you are trying to do?
Planar patch correct?
Planar is 2Dsketch.
Create workplane though 3 points (I used center of arcs).
Project Cut Edges.
Boundary Patch.
Not sure why you would do this part as Adaptive, but for sure if doing as adaptive I would fully constrain those arcs by adding Tangent constraints.
djchristophe
Thanks for the reply, I dont want the split to be on a flat 2d plane, I would like it to follow the silhouette curve ie form a 3d separation that is along the centreline of all 3 pipes. (The small pipe deviates in the Z direction as well as XY)
Cheers,
Chris
JDMather
After I fixed the tangecies you still had two tiny gaps in the 3D sketch.
Close those and the boundary patch works with your 3D sketch.
djchristophe
Thanks, I hadn't noticed the gaps. I've gone over and found 3 gaps which I've joined and 1 overlap and it will now create a boundary sketch. However the next step in my model is to extend this surface out 5mm (I'm creating a male press tool) but the extend tool is creating errors, which I guess may be linked to the overlaps and gaps in the boundary sketch.
Is there anyway I can create a better boundary sketch? I can understand why it would leave gaps and overlaps where it has. A collegue is working on a similar tool although slightly larger and is having no issues.
