Hi, could someone please assist me with this one:
I am using a macro to export the BOM (parts list) from a .idw to some excel file and would like to auto run this macro when saving the .idw. Before it was easy with the AutoSave macro, but not anymore with Inventor 2014. From what I understand an Add-In is the new way to do this. Could someone please explain to me in simple terms how to achieve this? (create the Add-in etc.)?
Many thanks
Reginald
Hi reginaldmb,
I think this is what you're looking for:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=17324828
Also just as a tip, you can search and ask programming questions of this type on the Inventor Customization forum too:
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/bd-p/120
I hope this helps.
Curtis
Hi Curtis
Thanks a lot for the reply. Will have a look at the info. Could you please have a look at another issue for me sometime which I posted a while ago:
http://forums.autodesk.com/t5/Inventor-General-Discussion/iLogic-iProperties/td-p/5048728
Many thanks
Reginad
