Inventor General Discussion
Valued Contributor
Ehsancad
Message 1 of 6 (190 Views)
Creating Adaptive Part
190 Views, 5 Replies
02-01-2010 06:00 AM
Hi all
I have a Flange with some holes distributed as circular pattern.
I put it in Assembly file & I want to add adaptive gasket on it by using Create Part Command in assembly.
I put a sketch on the red face and create extrude for project geometry of this face by 3 mm.
I found the the outer Diameter is just the only Adaptive.
If i change the number of holes ,it doesn't change automatically on the Gasket(new Created Part).
How can i make the number of holes related between gasket and flange?
Valued Mentor
delineryan
Message 2 of 6 (190 Views)
Re: Creating Adaptive Part
02-01-2010 06:24 AM in reply to: Ehsancad
I used the derived part command, exported the number of holes parameter. I have attached the files.
Ryan
Ryan
Inventor Version:
Build: 535, Release: 2011 SSR - Date: Fri 08/20/2010
64-Bit Edition - 8192.00 GB
Dell Precision T3500
Intel(R) Xeon(R) CPU W3540 @ 2.93GHz (8 CPUs), ~2.9GHz
6.00 GB RAM
Windows Vista™ Ultimate (6.0, Build 6002) Service Pack 2
NVIDIA Quadro FX 1800 8.17.0012.5849
**Master
BMiller63
Message 3 of 6 (190 Views)
02-01-2010 06:31 AM in reply to: Ehsancad
see this link also:
http://discussion.autodesk.com/forums/thread.jspa?messageID=5916090?
link above didn't seem to work, try this one:
http://discussion.autodesk.com/forums/thread.jspa?messageID=5916090䖺 Edited by: Bmiller63 on Feb 1, 2010 2:44 PM
Valued Contributor
Ehsancad
Message 4 of 6 (190 Views)
02-01-2010 06:41 AM in reply to: Ehsancad
Thank alot
Valued Contributor
Ehsancad
Message 5 of 6 (190 Views)
02-01-2010 08:22 AM in reply to: Ehsancad
How can we export Number of holes Parameter from flange to Gasket,in order to reuse it again?
Valued Mentor
delineryan
Message 6 of 6 (190 Views)
02-01-2010 08:28 AM in reply to: Ehsancad
Check off "Export Parameter" in the "Parameters" window. See pic,
Ryan
Ryan
Inventor Version:
6.00 GB RAM
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
